I play for ballroom dancing using my Roland BK-9 arranger keyboard with two Behringer B112W (1,000 watt each) powered speakers. The sound is OK but not as good as playing through my home stereo system: Cambridge Azur 640A and Klipsch 3 way speakers.
To improve the sound when out on a gig should I purchase a sub-woofer to go with the two 12” Behringer speakers. Or, should I ditch the Behringer speakers and get one decent 15 inch 3 way powered speaker?
Wall of Text Warning:
I'm using a fEARless F112 and an F115. Here are the specs on the F115
http://greenboy.us/cabs/view.php?model=FEARLESS F115
These are three-way cabinets that will handle up to 900W each and are full-range cabs that were originally designed for bass (they'll easily support the fundamental of the low B on a five-string). The sound quality on each (the F112 has a 12" driver) is identical, including in the low end; the only difference there is that the 15" will be louder. Both use a FaitalPro M5N12-80 5" mids driver and, I believe (mind is going) a 1" JBL tweeter. In both cases the LF driver is an Eminence Kappalite 3015LF (or 3012LF). These are not inexpensive cabinets.
Both cabinets have a "wedge" cut on one corner to allow them to be used as a floor monitor, and you can order them with a tophat for putting them on a speaker stand. The design is highly braced, but these are lightweight; my F112 weighs 34 lbs, the F115 weighs in at 43 (done in Okoume plywood), and the bass never farts out. I wanted something powerful and full-range that could be single-handed into a venue.
I'm running these with an external 1500W (RMS) stereo power amp that puts out 800W, bridged, mono, at 8 ohms (one cabinet) and 1500W at 4 ohms (both). When stacked, the two mids drivers reinforce one another, but I'll usually L-pad the bottom cabinet's tweeter.
I have a few comments about the Behringer B112W -- it's not a bad speaker setup, but they are built to a budget. Behringer doesn't publish RMS output for the amps (1000W is likely peak or music power). Frequency response is not published with a plus or minus dB rating (or plot). If you're experiencing a lack of fundamentals or wimpy bottom end, you'll definitely want to audition a subwoofer if you're going to continue using the Behringers. The bad news is that this is going to leave you with a three-speaker rig to carry into a gig. You may also want to consider a good 1/3-octave EQ and test the resulting rig with a good meter to find the peaks and valleys in the response.
