I uninstalled both drivers (Steinberg & ASIO4ALL).
So It seems I need to get an external USB Midi Interface (2 midi connectors as input and usb as output) which I believe would resample from my Yamaha 44100Hz to Jamulus 48000Hz. What do you think ?You should reinstall the Steinberg USB driver, which you can download from Yamaha's website. Even if you aren't using a USB connection to receive a USB audio signal from the P-515, apparently Jamulus requires an ASIO driver to provide a low-latency audio experience.
Even if you decide to use a stereo audio connection instead of a USB connection, I think the ASIO driver should be able to convert the audio being received by your computer into a format that Jamulus likes.
I really think your main problem was the audio sample rate. The P-515 outputs a 44100 sample rate, and it looks like Jamulus and/or the ASIO drivers you had installed were set to a 48000 sample rate.
If there's some reason why the Steinberg driver won't work with your computer's sound card, you can install the ASIO4ALL driver instead, in which case I assume you'll need to use an audio connection rather than a USB connection, since I doubt that the P-515's USB signal can be properly decoded by the ASIO4ALL driver.
MIDI has nothing to do with it.So It seems I need to get an external USB Midi Interface (2 midi connectors as input and usb as output) which I believe would resample from my Yamaha 44100Hz to Jamulus 48000Hz. What do you think ?
