I have used my Encore music-editing software on my lapop for years, but just connected a keyboard for the first time to do step input from the keyboard.
I initially purchased a Hosa USB/MIDI adapter for use with my old Yamaha V50. However, after the first few notes, the software quit recording notes, and I had to close, then re-open the software to get a few more.
Assuming the problem was perhaps the vintage of the V50 (which has a dead internal battery anyway) in combination with newer technologies, I returned the Hosa adapter and instead purchased a Yamaha YPT-330 (PSR-E333) keyboard, which has an integrated USB MIDI interface.
I get the same behavior: the first few notes appear on the screen as I play them, and then the software quits responding to the MIDI input.Thh program does not freeze, as I can still input notes manually via my mouse and otherwise interact with it, including local playback via the computer sound card. I have to close & re-open the program to get it to work for a few more notes.
I just downloaded & installed the Yamaha standard USB/MIDI driver, carefully following the installation instructions, but it changed nothing. I removed all USB devices except keyboard/mouse & the MIDI cable, also to no avail.
Is there a trick to getting MIDI data to transmit reliably from the keyboard to the computer? I am doing step input only, not realtime recording, so timing should not be an issue.
Because this is connected to a laptop in a docking station, I cannot just add a PCI card for my MIDI interface. I already posted this issue to an Encore forum but have not yet received any responses.
