USB Sticks for Yamaha Keyboards
Hi guys
Im after finding out if i can use any USB stick or if i need a special Yamaha USB stick to put expansion packs on my new S650. any info will be grateful.
Baz82
As far as I know, there's no such thing as a "special" USB stick. Yamaha might require some special formatting of a generic stick, but the only limitation you should look out for is maximum capacity the keyboard can handle. (ie. how many gigs)
Formatting can usually be handled by a utility built into the keyboard itself.
Sweden
Hej Baz82,
page 53 of the manual:
USB storage devices (flash memory, etc.)
The instrument does not necessarily support all commercially available USB devices. Yamaha cannot guarantee operation of USB devices that you purchase. Before purchasing a USB device for use with this instrument, please visit the following web page:
http://download.yamaha.com/
In your case I think most of the USB-Sticks will work without problems; but in all cases I would format the stick in the keyboard (page 56 of the manual).
Hej Baz82,
cheers mate.
