Used arranger/workstations, which one ?
Hi, i'm looking for a good quality used arranger/workstation which has step record mode as a must. I have an old technics KN2600 keyboard which has served me well for the past 20 years, ahead oof its time but is now at the end of its life. I make backing tracks (mostly country songs) and arrange music for a small orchestra so an older keyboard with realistic sounding instruments and a 16 track sequencer is a must as is the step record mode. Would consider any make or model but working on a tight budget of around £200/300 I realise this is a big ask. Would appreciate any suggestions as to what to buy and what to avoid just to get an idea what is out there
First thoughts a Korg Pa300 or 600 but if you watch this video it will give you a flavour of the three recording modes that are available with each model.
The 600 has more Styles and Sounds than the 300.
