Hey gang.
So, I'm trying to get a basic Hammond organ setup working, assigning the draw bars to the sliders of my Oxygen. The VST I'm using is the VB3, and I'm using a Receptor as my main midi machine. The trouble I'm having is that when I try to assign the sliders to the draw bars, only certain ones get picked up, when I use smart learn. It can pick up C2, and C7, but all the others, it doesn't notice them transmitting. The Oxygen seems to think that they are transmitting on the global channel. So I really have no idea what I'm doing wrong here. Setting the VST to listen to all midi channels doesn't help either. Any idea what I'm missing? (I've also tried a factory reset, in case some weird settings had gotten in there). All help is appreciated!
