I knew I had them somewhere...I had contacted Mark Vail of Keyboard Magazine in 2001, I've really had the V5 (before I got the V5+) that long ago!!! Anyway, Mark told me he contacted Dave Amels (the Voce V5 designer) and he said the 7 preset drawbar registrations were:
VOCE V5+ PRESET DRAWBAR REGISTRATIONS
Preset 1: 888000008
Preset 2: 808808008
Preset 3: 888888888
Preset 4: 888800000
Preset 5: 888473256
Preset 6: 828000000
Preset 7: 878420000
According to the manual, these factory presets can be recalled, if you change any, by turning the unit off and hold down the
Percussion On/Off and the 2nd/3rd Harmonic buttons simultaneously while turning on the unit's power.
Hopefully, this will help any keyboardists still using a VOCE V5 / V5+!
Here's another tip...make sure if you replace the power adapter for these units that it is a 12 volt "AC" and NOT a 12 volt "DC" adapter.
I made that mistake and got nothing but a buzz when activating the unit from a MIDI keyboard controller.
Tommy B
