Volumes!.
Hi guys,so I'm finally set up with my Dgx 660,connected to a looper and an amp so I can sit down and jam anytime,love it but!its all the same volume.Can anyone advise me of what I need to use for layering the volume ??
If I assume that you do not adjust the DGX volume for each recording layer would I be correct?
If I am correct play around with the levels you are sending from the DGX to the looper with is no doubt a Boss RC model or similar.
I have a Boss GT100 and use this technique when I am laying down guitar/bass tracks, I use the inbuilt expression pedal to vary the signal volume.
Thanks Mr Biggles it worked good man yourself,it sounds so much better!!!..;)
