- Joined
- Jan 24, 2014
- Messages
- 26
- Reaction score
- 0
Weighted Piano Action vs. Weighted Hammer Piano Action; terminology differences? Referring to the same thing?
Is there an actual difference between Weighted Piano Action vs. Weighted Hammer Piano Action. It looks like different manufacturers label their action using different terminology, and I have yet to discover a term used across the board between different keyboard makers to describe keyboard action.
It’s my understanding that Weighted Piano Action keyboards are referring to a keyboards where small weights have been put underneath the keys to give weight to the keys. Weighted Hammer Piano Action keyboard, actually have small hammer devices similar to those on a real piano installed in the keyboard to simulate playing on a real piano. Is this correct?
Another thought I had was that any keyboard that uses hammers like a real piano would just be considered Weighted Piano Action and any of the keyboard that don't use hammers, but still have weights in them would maybe be considered Semi-Weighted keyboards? This would eliminate the need to use the term Weighted Hammer Piano Action. I don't know.
Can someone please clarify?
Thanks.
Thank you.
Thanks.
Thank you.
