I was about to say that it it is far more recent than "before turn of the century." Most keyboards from that era also had a Midi Though socket. The P80 still sells on Reverb for around $250 -300 so if you can get it for around €50, you've got a bargain, assuming it's working okay. Putting it into a piano case like that certainly is a bit dumb, as there is no access to any of the buttons, etc.I found the model of the 60 euro one, its a yamaha p80
HoiWhat kind of Neanderthal chops up an upright piano and sticks an electronic keyboard into it?
I have no idea of the make or model but it does have proper MIDI ports so you could use it as a MIDI controller for a DAW.
It also has line outs so it does have some sort of built in voices, probably a low end stage piano from Yamaha or Casio but it looks like a real antique. It appears to have some sort of weird ass DIN connector for a PC.
That probably dates it back before the turn of the century.
I can't tell if it has speakers built in or not from the photos.
It might have been made by Creative Labs when they bought EMU Systems.
To be honest you're buying a pig in a poke and I wouldn't be willing to pay more than $75 for it.
It's ancient, it's off brand, and it has non standard connections. Probably will die within 6 months after it starts to see regular use.
