What comes before an absolute beginner?
I have been a fan of the sound of keyboards for a long time. My music taste allows me to appreciate anything from Moog to Fender Rhodes. I want a go myself. Just for fun. I have tried to find out more about MIDI and VST and how to get a computer to be the engine of the sounds I am after but there are no real beginner guides. All seem to be in a different language.
So my question is this; What do I need to add to a laptop to sequence sounds and/or play a midi keyboard and have a range of cool sounds to play with.
I really hope someone can help. My question seems so basic I really shouldn't be stuck, but I am.
I'd say to start out you need a decent controller.
http://www.akaipro.com/mpk49
I don't recommend the M-Audio Oxygen 49 since I own one and find the keys very mushy and unresponsive and utterly useless with velocity switched on.
Then you can pick up whatever DAW/VST software your heart desires.
I'd recommend Cakewalk's Music Creator 6 which is a full featured DAW with some good VST plugins included for under $50.
http://www.cakewalk.com/Products/MusicCreator/
You could also Google for freeware VSTs and DAWs as well but the stuff I listed should get you started with minimum muss and fuss.
If you need beginners' instructions on setting up, Cakewalk offers some tutorial videos to help get you started.
http://www.cakewalk.com/CakeTV/Music-Creator.aspx
Thanks very much for that. I've seen that keyboard on ebay at a good price. I'll take a look at Cakewalk too.
Thanks for your help.
