- Joined
- Dec 12, 2013
- Messages
- 1
- Reaction score
- 0
Hi,
I'm a relatively beginner piano player and don't have much experience.I will mostly be using the keyboard to play jazz and Funk.
I need to buy an 88 key hammer action keyboard with a large variety of sounds that are suitable for jazz. My budget is around $1000. Could anyone tell me what I should take into consideration? Any suggestions?
I have checked out the Korg Kross 88, Casio Privia PX-5s and kurzweil PC3 LE8.
I would prefer buying the korg kross 88 since it is also a workstation and it is cheaper than the kurzweil. But I read somewhere that Korgs are used for rock and the sounds are more suited for rock however i'm not sure if that is true. I would really appreciate it if you could help me out and give me some more options to look at.
Thank you so much
Behrooz
Thank you so much
Behrooz
