One friend wanted to learn piano and bought a fairly decent 61-key casio, then found out not enough keys for his exercises half a year later.
I agree. I think it was because of the piece of music he was asked to work on. The left-hand part was far away from right-hand part, even though each hand only works within its own octave i think he could have used the built-in feature to simply shift the whole keyboard one octave down and that would work, but I guess he didn't know how, and only talked about it after changing keyboardI'm trying to figure out what beginner exercises would extend beyond a five octave keyboard.
Hi Ray,https://au.yamaha.com/en/products/m...boards/portable_keyboards/psr-i455/index.html
Read this and decide for yourself if it has all of the features which you desire.
This is an excellent choice of instrument for a beginner and will give you much joy as your experience develops.
But if you want to play classical then you might want look at 88 keys. This one only has 61 keys.
Ray
At this point my focus is on electronic keyboards.What are your goals with your keyboard playing? Are you planning on playing piano, or sticking with electronic keyboards? IF you're planning on going the piano route, you really should learn on something with 88 weighted keys. If not, then a five octave unweighted keyboard should be fine. (Don't go less than five octaves on your first keyboard.)
Then a five octave unweighted keyboard would be fine for you. The next question has to do with how you want to play and your eventual goal. This is the big arranger keyboard question.
If your goal is to just have fun, or to be a "one man band" with full accompaniment, then you may want to get an arranger. Arrangers have built in rhythms and full accompaniment, usually controlled by the chords (or notes) you play with your left hand. If you're playing with a singer or a solo instrument (saxophone, etc.), then this could very well be the way you want to go. (The Yamaha PSR series of keyboards are all arrangers.)
But if you want to play more complex music where you have more control over what the bass is doing, or if you want to play with a drummer and/or bass player, then arranger features are far less important to you. You can use an arranger to play more traditionally, but it becomes very easy to start relying on the auto-accompaniment features and let your left hand stay weak. (An example of more complex music would be playing a piece like Money by Pink Floyd. The bass line is essential to the piece, and it's not in a "normal" time signature. I doubt that you'd be able to play it well using auto-accompaniment features.)
One advantage of an arranger, especially for a beginner, is that you have to buy less stuff. Most arrangers have built in speakers, so you won't have to buy an amplifier and speakers. But if you want to play out, you'll still need to get some sort of real amplification for gigs. Eventually. When you're good enough.
I own an arranger, a Tyros 5. (I wouldn't recommend it to a beginner; it's a bit pricy.) Even if I skip the arranger features, it has some really nice sounds built in, interesting ensemble features which automatically allocate instruments, vocal processing, and easily accessible splits and layers. So its quite usable even excluding the auto-accompaniment.
The other question is your budget. I wouldn't spend a lot of money for a first keyboard. You can always upgrade as you outgrow your keyboard.
I want to be a part of a band. I am very new to music but I am very eager to achieve something in music.Then a five octave unweighted keyboard would be fine for you. The next question has to do with how you want to play and your eventual goal. This is the big arranger keyboard question.
