- Joined
- Oct 1, 2007
- Messages
- 246
- Reaction score
- 1
I was playing my keyboard when I noticed a 'click' sound when I played the D after Middle C. Some kind of little object had gotten under the key!
I picked up the keyboard, turned it upside down and shook it. Sure enough, the little object was shaken away & the key sounded fine.
Only trouble is, that little thing is still floating around somewhere inside my keyboard's guts. I don't like that idea. What if it gets inside something important & screws it up?
How do you prevent crap from getting inside your keybd, and if it does, what can you do about it? I'm not sure I feel like taking this to a service tech as it's not really a problem right now. Also not sure how practical it is to think about opening the board up.
Crap getting under the keys is usually the nemesis of any piano!!
