Oogie Wa Wa
Nate, bass and keys for The Feds Band
I play bass. Key bass/keys half the time, and bass guitar the rest, during our 3-piece band live gigs. I just got a 32 key controller to use just for bass only, to use as an input to my Juno DS61, via wired MIDI. It works fine, no issues or questions there. This gives me a lot more room for my right hand to romp around on on the DS.
It's time to figure out where to physically mount that second, smaller board for playing bass.
I'm looking for orientation recommendations, especially if you use a similar setup. So what works best for you folks; put it above or below the main board? To the far left I suppose, but offset how far back/forward between the fronts? And how far above/below? Angles?
OR, If you always use two full keyboards, which one do you normally play bass on, upper or lower? That would help.
I'll figure out the how once I determine the where, that's not what I'm after yet. I'm "handy" and will make my own mounts. Thanks folks, input much appreciated!
Oh: I also sit about a fourth of the time, so please take that into consideration. And I do not need much access to the panel above the keys on the controller while playing.
