Hi, I have projects with Midi tracks that do not allow the Freeze sound function of the synthesizer from a bank that I set. Instead, after the Freeze process is completed, are always is used №22 sound, regardless of which synthesizer or DAW. I suspect some malware has corrupted the all Midi files . For this, please list me all the possible programs that can open a Midi file so that the parameters are well visible and after changing this setting it is replaced with something which means that it is allowed for each sound number.
I opened with text editors - Sublime, Notepad, Atom but what I see is that there is not a single digit 22. There is nothing clear about it. For this, I ask for programs that are geared to open Midi files in this way to see the settings that looks something like a text document or table . In the music project, this is not visible and I cannot in any way remove it from DAW. There is always №22 sound used . And it will be difficult for me to repeat the played notes in all tracks and all projects.
