- Joined
- Apr 26, 2019
- Messages
- 584
- Reaction score
- 158
Question about a K&M X-Stand.
I’m going to buy a Kawai ES110 this week, with a solid X-stand.
But I’m not sure which would be best :
18990 Keyboard stand »Rick«
Rubber rests can be ajusted:
- Maximum 360 mm from end to end, 250 mm between the rests
- Minimum 300 mm from end to end, 190 mm between the rests
18993 Keyboard stand »Rick 20«
- fixed at 260 mm from end to end
The depth of the ES110 is 286 mm.
Now, according to the manual of the ‘Rick 20’, it’s best to have the keyboard overlap the supports by a couple of centimeter front and back.
This would certainly be the case with the 18993 ’Rick 20’ ; same with the 18990 ’Rick’ but if I align the ES110 with the rubbers, it would be a bit ‘off center’, because the rubber rests can only be moved on the back of the stand (they can be move forward or backward), if you know what I mean.
X-Stands are not ideal for stability, but these models from K&M seem to have a very good reputation nonetheless. But is there any reason to choose one over the other for the Kawai ES110 ? Which one would be the more ‘wobble free’ ?
Any 'stand' experts here ?
Our best X stand - comfortable and extremely sturdy. The new design of the double brace stand tubes provides for perceptible stability and safety. The ergonomic clamping lever makes it easy to…
www.k-m.de
Comfortable and extremely sturdy X-stand for stage pianos. The new design of the double brace stand tubes provides for perceptible stability and safety. The ergonomic clamping lever makes it easy to…
www.k-m.de
