Why are Mechanical Keyboards So Expensive
Mechanical keyboards are very costly, which is a bit complicated. In mechanical keyboard, modern technology is used and the main point that makes technical unique and expensive is, switches are used under each key.
It sounds like you're talking about computer keyboards. These forums are dedicated to musical keyboards, not computer keyboards. :)
We really need a bigger keyboard logo.
JerryK47
