It took me a while to find one, but I got a used Roland A33 76 key controller and it's just what I was after. 88 is too big and heavy, and 61 keys just isn't enough for live performance. I'm surprised more vendors don't make 73 or 76 key devices!
Not really. The vast majority of soundless MIDI controllers are no more than about $1200 (mostly far less), and I think the only 7x-key boards you might call stage pianos in that price range are Yamaha P-121 and NP-23, and they don't make for great controllers, unless maybe ALL you need is a set of keys, a USB connection, and a sustain pedal. There's no MIDI zoning, no pitch/mod wheels, no 5-pin MIDI connectors, no expression pedal jack, no sliders/knobs. But if you stretch a little in price, you can look at Studiologic Numa X Piano 73 and Kurzweil SP6-7. For any other possibilities, I think you'd have to top $2k. At any rate, there's not loads of them, and especially not in the typical "controller" price range.Any 76 key stage piano can fill the bill as a controller.
There are loads of them out there for about the same price as a 76 or 73 controller.
