wk 7500 volume control not working
Montana
Has anyone had a problem with the volume control on the wk7500? Mine is stuck on one volume only when I play through the internal speakers. The only way I can change volume is to play through an amp and use the volume control on the amp. Any help would be appreciated.
First of all try a factory reset.
If that doesn't fix the problem and it's still under warranty, send it back to Casio for repair.
Otherwise, if it's out of warranty, get a tech to replace the volume potentiometer. Or replace it yourself if you're a handy sort of DIY sorta guy.
