Ok, I have both a WK500 and a WK3200. The 500 is now my prototype, and the 3200 is my baby.
So, anyway, I plan 2 mods. Wonder if anyone here have tried these before:
1. This one I'm going to do on the WK500 first and perfect there...then move to the WK3200. I purchased small adhesive weights that are used to balance car wheels. I plan to stick these inside each of the keys of the keyboard to create a semi-weighted keyboard. If necessary, I'll be adding a strip of foam (the kind you use to cover water pipes) under the keys to make them a little heavier, as adding the weights will actually make the action a little lighter than it already is, and I don't want to over-stress the rubber thingies that sit under the keys. What this mod mainly does is make the keys bouncy, similar the action I had on my old Kawai K4 and Korg DS8. I've already done a little prototyping by sticking weights (temporarily with tape) to the underneath of the white keys on my WK3200. Since I could do that without opening up the keyboard, it was easy to test. The result was amazing!! I couldn't believe it was so easy. So, anyway, I'll post my results here.
2. On my WK3200, I plan to see if I can tap into the circuit board for the modulation button, and add a jack (for a footswitch) that I'll primarily use to change the leslie speed for the drawbar organs. I did a mod like this many years ago on a Korg Poly-Six (routed the "hold" button to a jack, so I could create a simple sustain-like pedal). I realize this could be tricky...soldering onto a circuit board...but I think I can be careful enough not to fry it (I HOPE!!!). I'm most nervous about this, because the 3200 is my main keyboard...and I hate to mess it up. I'm currently using a Behringer BCR2000 via MIDI to trigger the leslie with a foot pedal, but I'd like to be a bit more compact (because it's overkill to lug that unit around just for this one function).
Anyway, has anyone out there tried these mods before??
