hi I m new here/ Ive worked on quite a few digital pianos but have never run across this issue- every thing seems to work properly, except when you hold down a c or d and play the c or d of the same octave it sounds twice as loud and slightly distorted /also the f s and g"s/this happens on all octaves / when played singly all keys work properly /no other combinations have this problem /ran the test procedures found a ng on the wave rom ck/did a factory reset /cleaned the contact strip and boards /tried two different sets of the contact pc boards -no change in behavior/ never heard of this before /thinking it must be a mother board problem --any advice would be most appreciated thank you
