Yamaha DGX-230 Portable Grand power and sound issues
sandy ego (san diego ca)
i got a dgx230 the other day second hand
it turns on well but sometimes when i turn it on the LCD is dim, noise is really quiet (or sometimes you cant even hear anything), low notes make buzzing sounds, and if it turns on properly if i slam on the low keys enough it restarts for some reason and goes quiet again
anyways i think the phones output may have something to do with it because if i plug in and unplug it'll go back to normal, but if i press the low notes one too many times it'll restart and go quiet again like i said
i use the built in speakers and rarely use the line out, just to plug and unplug so it'll go back to normal, but i do need the speakers working
Mkuhl
