Yamaha DGX 66O bass sound enhancement!
Lor
Hi Guys
I’m new in DGX 66O Yamaha keyboard!
Can anyone advise me how to enhance the deeper bass sound quality !
Either change the speaker or simply buy a subwoofer?
Thank you
Stay safe
If you already have good monitors, just add a subwoofer. Nothing fancy.. 8 inches will do. I use a similar setup.
Lincoln UK
As Biggles suggested adjust EQ to your liking, on same page you can Increase GAIN, suggest only small amounts.
Compression TYPE Try setting POWER, and press switch on Button.
SAVE IN Parameter Lock.
