I am looking for a used keyboard for my son, he is 13 and plays piano and keyboard by ear quite well.
I already have a Yamaha Acoustic Piano and a Kurzweil PC3X which we both play on.
I have seen a used Yamaha EX5 and also a used Yamaha MM6, the MM6 is about $150 dearer.
He likes piano but also keyboards as well, I am assuming the MM6 would have the better piano sound but with 61 keys it would be limited. I also like the action on the EX5 as well as the extra octave, I am not sure if the action on the MM6 is good or just plastic.
I owned in the past a DX7 and a Korg M1 both of which had great action and feel...same key bed I think, the keys have a rib underneath unlike the cheap plastic feeling actions. I had a Korg Triron LE 76 and the action was so cheap and nasty it was virtually unplayable to me, the Korg X5 and N5 was the same and I am wondering if the MM6 is a cheap/nasty keyboard or is it really good?
I guess what I am asking is it better to by an older high end model (EX5) or a newer entry level model (MM6)?
We just want to jam on it and have fun, he will probably get more into the editing than I will.
So EX5 versus MM6 or even if I find one MO6, any tips and opinions would be much appreciated
