Hello!
I was looking to upgrade my old Yamaha PSR. I got the Roland XPS-10 and, to my surprise, most organ and harpsichord sounds had no touch/key sensitivity. It's as if it was set to off for all those sounds. I'd hate to perform like that so I returned it.
Next in line was the new Casio CT-s500. I've heard tons of good reviews etc. so I gave it a shot. It arrived today. First impression was that sounds were really sub-par. And, lo and behold, touch response (key sensitivity) is off for organ sounds. I'd rather play on my old PSR from the 1990's then.
My next choice in line would be the MX61. It's almost twice as expensive as the CT-s500 and I won't use most of its features; I don't need lots of sound editing features, just some basic sounds. But I will not play organ sounds without keys that support dynamic presses. Does anyone know whether the MX61 also has this limitation?
I don't understand why both the Roland and the Casio would have it. Realistic, yes, but why not give people the choice? Switching the setting to off would be easy enough for those wanting to play these instruments the more realistic way.
Thanks a bunch!
Thanks a bunch!
