- Joined
- Feb 27, 2023
- Messages
- 2
- Reaction score
- 0
Hey guys, i've had my MODX8 for a few months and have recently started noticing issues with the touch screen becoming unresponsive. If i replace the LCD assembly might this solve the problem?
Thanks will try that..I forgot to mention tho, I changed the power supply, same 12V but instead of 1.5amps I used one with 2.5 amps..can that affect the touch screen in any way?Actually if it's the cheaper resistive type of LCD touch panel just take a kleenex with a few drops of alcohol and clean the screen well, especially paying attention to the edges and corners of the screen. It should pull out the black gunk from your fingertips.
DON'T douse the screen with alcohol directly. Just use a moistened kleenex.
Let me know if this works for ya.
THE PROBLEM WAS NOT THE DISPLAY!!!Hey guys, i've had my MODX8 for a few months and have recently started noticing issues with the touch screen becoming unresponsive. If i replace the LCD assembly might this solve the problem?
