Yamaha MX61 - Best Sound to Play Midnight Oil's "Beds are Burning?"
What would be the best sounds to mimmic the brass being played on "Beds are Burning" using a Yamaha MX61?
I've only just listened to it for the first time, but it sounded like a Synth Brass sound, so you could try whatever Synth Brass voices the MX61 has. Once you find one or two that come close, you could try layering two of them together, or doubling one of them in different octaves, tinkering with the cutoff/resonance, etc.
Rajitha
