Hello all,
I posted a while back about the right channel of my P200 digital piano cutting in and out, and thought I had fixed the problem. Unfortunately I had not, and the problem persists. Basically, the right channel will be almost completely out or very scratchy, in every channel (speakers, headphones, stereo outs), and if I hit a big chord or tap the correct spot from underneath, it springs back to life for a while.
After many hours of eliminating different possibilities, I've finally more or less pinpointed where the problem is coming from. There's a section of the power amp circuit board with a relay that leads to a snap connection where the left/right signals leave the power amp (white wires/connection in the close-up pic below). If I take a chopstick and push down gently on the circuit board itself anywhere near that connection/relay, the right channel immediately comes back to life. I do not believe the problem is in any of the wires or the snap connection itself, as moving the wires around does not have the same effect. Does anyone have any ideas on what the problem could be? Is the circuit board shot with no hope? Could the relay be faulty and need replaced? I'm confident enough replacing components so if anyone has a solid guess based on the description, I would greatly appreciate it! Pictures below along with a link to the repair manual page with the circuit board in question. Thanks a ton!
https://www.manualslib.com/manual/1114969/Yamaha-P-200.html?page=20#manual
