Yamaha PF1000 no sound
Hi everybody, I've recently bought a used Yamaha PF1000. It played good then. But now when i press the keys no sound is heard, i tried Metronome it has sound...Does anyone give me advice how to fix it, or where i can ask for it? Thanks in advance
I am not sure cause i've never used it . I need MIDI cable to test it, don't i? Please tell me how to do this! Thanks
Canada
I would check if the Local Control has been turned off (see page 134 in the user manual).
When local is off, the keyboard only sends MIDI messages without producing sounds through its tone generator.
You could also check the speaker settings (page 138), but it's probably OK because you hear the metronome.
Or maybe performing a factory reset (page 140): if it fails, then we'll know it's a hardware problem (bad...).
Good luck!
I tried all those steps, but it doesn't work...Maybe bad hardware...Thank you very much. I will find the local service to repair it
