Yamaha PSR 295 or PSR i425? Help..
Hi Guys,
Im so glad to find this place where I can get your expert opinions and guidance..
Im a guitarist and very very new to piano\keyboard world..
So I thought of buying a keyboard.. Im getting a good deal on PSR 295 and PSR i425..
I am getting PSR 295 for 150$ and PSR i425 for 270$..
I am not able to find much difference in two models accept indian styles..
Kindly suggest which one to go for and why?? Also if u know, then plz be kind to mention the difference..
Thank you so much for ur help...
Hi,
Thanks for reply..
Just want to know from knowledgable ppl here, is the difference between two models very great or just a little? Coz if its just a little, then I dont think I shud go for i425 at double the cost.. What do u guys suggest?
Also cant I load styles into Yamaha PSR-295 via USB?
Thank you.
In that case, which ones are cost effective yamaha keyboard for beginners in which one can load styles etc.??
