Hello everyone, new member here. I have a Yamaha PSR 400 portable keyboard that no longer powers on properly. Either on a power adapter that I have used forever and new batteries. When I power it up it starts to spell out Error on the display. Interestingly, it spells it backwards several times then after several times of that shows Err. I can get it to come on semi- normal if I hold down the clear button while turning on the power. I can also hear a very slight sound of the speakers getting initial power, but if I touch any key or button that should produce sound, it goes to Error and then nothing. the keyboard has been setting unused for some time now and has gone through Hurricane Michael, but I don't think it got wet. The power jack on the back looked to me like it had some corrosion in it where the cord plugs in and I cleaned that up real well. I figured this would cure the problem, but figured wrong. Same issue. I also opened it up looking for any really obvious problems, but didn't find anything. Now I am at a loss for what to look for next. It really acts to me like it doesn't get power enough to do what it needs to be doing. The power adapters I use,( and have been using) are 12v and 1000 ma units. They both test well on multi-meters so I don't think the problem lies within them. Any help and advice would be greatly appreciated in getting this thing going again. Thank you in advance to all.
