Yamaha PSR 8000 Sounds
Hello,
I'm using the Yamaha PSR 8000 keyboard, but would like to get some new sounds on it. I've never really tried this, so how can I do that?
In particular I'd really like to get some Hammond sounds on it.
It would also be nice to get some new drums ect... But I'm really longing for those Hammond sounds! :)
Thanks a lot for your help!
That's one huge keyboard you have there :)
Unfortunately, like all other PSR keyboards, you are limited to the internal ROM provided with the keyboard. You can't add new samples.
You could tweak a bit the preset sounds, but on PSRs that's just making small
adjustments like reverb/chorus... So, sorry... Don't think you'll have much luck with that.
You could get new user styles though - same drum kits though.
