Hello,
I was wondering if you can connect a PSR E343 directly to an iPad (4th gen) using a camera connection kit - which seems working on the PSR E433- or if I need the iUX1 cable plus a lightning connector adaptor - more cumbersome and costly solution - as described in Yamaha iPad connection manual.
Btw when paired with an iPad how does the recording capabilities of the 343 compare with 433 model?
As far as I can see It as the advantage of the audio in!
Cheers,
FranZ
Cheers,
FranZ
