Yamaha psr e463
Hello! can anyone help me with the problem in my yamaha psr e463 keyboard? The main variation button is not working what Im gonna do with it? Thanks! or is there other options for changing the main variatio from A to B?
If you have tried both Reset procedures & no change then it is probably a fault with the switch.
A DIY task you for you?
Switches should be readily available from Electronics Store or Keyboard Repairers
Otherwise trash it and buy a new model as a Service Tech will charge more than then keyboard is worth.
Rajitha
