Yamaha psr sx 900 congo bongo styles/loops
Hi - I am looking for some congo bongo 4/4 (mainly) and other similar styles/loops for yamaha psr sx 900. Surprisingly enough - they dont have any preset in the keyboard for that sound. Of course ballads have 4/4 styles, but no congo bongo sound in particular! Any help is appreciated if someone knows of any yamaha downloads or other styles accepted by psr that can help. Thank you in advance!
Texas USA
Have you auditioned the multipads? They work like styles and fills but often contain arps and drum loops. They are also editable (by copying and saving as a user multipad.) If a style has a drum fill or flam that you like, you can also snip out that part of the style as a MIDI, and save it into a custom multipad.
The PSR-SX900 has a ton of factory content, only a little less than the Genos. Keep searching, you might find something usable in there. My $.02.
sberry1
