Yamaha PSR295 vs Yamaha F51
Hello friends,
I am just starting to learn Piano. For that, I am buying a Yamaha Piano. I am confused between these both variants :
Yamaha PSR295 --- 7000 Indian Rupees
Yamaha F51 ---- 6000 Indian Rupees.
I am a complete noob in terms of Piano, with no ear.. :-D . The difference in terms of costs is not that much between these 2. Which one should I go for?
I am interested in basic melody playing, cover songs, having fun, nothing professional, I work full time, and happy with my job. :)
Thank you.
Regards,
Akshay S
Welcome
Are these new or second hand?
Both would seem to be low end instruments given that a Yamaha PSR i500 is 22000 Rupees or about £250 which even then is not a lot for what is a starter keyboard.
The F51 is the entry point keyboard and in reality is a very cheap unit.
I would suggest spending more and buying a top of the ranger starter keyboard that has the inbuilt Indian Styles if indeed that is the type that you want to play.
Hence I suggest you consider the Yamaha PSR i500
Or
A Casio CT X model, there are three to choose
Welcome
Or
I500 is very costly for me..... Can u recommend one of these 2. Both are new btw. :)
The PSR-F51 is not velocity sensitive, or what Yamaha calls touch sensitive, and I don't think it has a song recorder or registrations. The PSR-295 is an older model, but it has touch sensitivity, a song recorder, and registrations-- so despite being a much older model than the PSR-F51, it's a much better keyboard.
Rajitha
