Yamaha sx900 chord tutor
India
Hi in yamaha sx900 chord tutor shows different notes for c major and other chords in general. I think it shows c major 2nd inversion keys. Any inputs on how to correct this??
Welcome.
The manual does show 2nd inversion, but it true Yamaha confusion in the Function menu there are a couple of options which you may want to try.
You may want to also check out the different fingering modes as changing them may give a different result.
Printing out a Chord Chart and using that to learn the chords would IMO be more useful.
Sorry I cannot be more helpful
India
Just changing the split key solved the problem gave more space/keys to the chord section.
KeyboardMon
