Yamaha ypg-535 Speakers Grille Removal
Fellows.
Does anyone know, how to remove the Grille over the Speakers on Yamaha YPG-535
Is the Grille popup type by prying with screw driver. I do not see any visible screws.
Like to remove the Grille to clean the surface of speakers. High powered Vac, does not
do the job.
Thank you.
00jungleman
If you want to service your YPG-535, I'd recommend looking at the service manual:
You will probably need to remove the entire top of the casing, or something like that. And once you've cleaned it, you'll want to get a good dust cover for your keyboard. These guys make waterproof custom vinyl covers:
