Yamaha YPT-220 / PSR-E223 No sound, powers on
Hello everybody!
I have Yamaha YPT-220 / PSR-E223. It powers on, respond to keys (i can see on the display that the proper keys are pressed). Unfortunately, there is no sound at all. I checked on headphones, speakers - nothing, no humming etc. Dead silent.
I read on one of the forums that replacing BA5417 might help, but after the replacement everything is still the same - no sound.
What could cause the problem? I checked and found out that two capacitors are shortened... I don't think they should be, but I am not sure (I am not a proffesional electronic technician, but I know how to replace resistors, capacitors, IC's etc).
Here is the video of the two elements that I found out are shortened...
What are your suggestions? What could help and what else should I check?
Thank you.
How can I do that? I am not a professional repair technician, but I know the basics on how to use voltage meter and replace electronic elements.
Can you please give me a hint how to check that? I would be really greatful
Hello everybody!
Thank you.
I had the same problem. I took a multimeter and checked the capacitors in the ringing mode, one turned out to be punched. See the photo.
Rajitha
