Yamaha YPT210
Hi there,
I am returning to owning a keyboard after selling a yamaha NP30 18 months ago (which I regret selling)...
My budget is pretty much a max of just £75. I have read great reviews of the Yamaha YPT210 (which I can get for my budget) but am concerned that the keys are not touch sensitive. I play mostly piano but my budget doesn't stretch to the £144 of the Yamaha PSR e323 - basically double the cost! I sold the NP30 because my interest waned - I'm worried that the same will happen again and the more I spend will be wasted. I basically want a cheap keyboard to see if I can get back into it again...Even on Ebay prices for the e323 are higher than my budget secondhand....
Any advice would be welcome...
Cleveland
how long have you played for before you sold your np30?
if you are a beginner then the Yamaha YPT210 may not be too much of a problem, however if you are anywhere past a beginner i would save up and get something better.
m88
