- Joined
- Sep 26, 2007
- Messages
- 129
- Reaction score
- 0
Already introduced myself at the introduction forums, so I'll skip that.
I'm looking for advice on buying a keyboard. Price range is ~$1500, give or take.
List of essential features I'm looking for:
1. Velocity sensitive keys(my previous didn't have this), aftertouch.
2. 88 keys(I have my heart set on that)
3. Sounds: Piano, Choirs, Organs, Orchestral ensembles such as strings, brass.
4. Suitable for recording and live performance and all that entails such the proper inputs and outputs, ease of use etc.. weight isn't an issue.
5. Pitchbend wheel.
List of non-essential, but still very desired features:
1. Hammer action/weighted keys, preferably with adjustable weight.
2. Sound: A good synth so that I can mess around with lead sounds to my liking. More built-in instrument sounds would be nice.
3. Sustain and other funky pedal support(volume, pitchbend, effects etc...).
4. A nice good display.
5. Resale value incase I end up wanting a different keyboard.
6. Ability to hook in other midi-controllers to the keyboard that are assigned to their own sounds so that I don't have to split the keyboard into sections and for ease of live play.
7. Extendability(things like extra sound modules, memory etc...)
List of features that I wouldn't mind not paying for:
1. Sequencing
2. Sampling
Some other things to take into consideration: The style of music will be powermetal, so the majority of my contribution to the band will be harmonic support in the forms of choirs and strings, riffy/arpegio support with sounds like organs and optionally some lead parts if I can get the proper sounds(not too keen on using overly electronic sounds). I want to be as expressive as possible if I do play lead.
There is still alot I'm confused about or don't understand, and my list of requirements will change to reflect this over time, but for now any suggestions on what models to research or advice on what other features I'll need or would find usefull would be very appreciated. I have time on my side, since the soonest I will decide to buy anything will be in two weeks, and in the meantime I'll be doing alot of research and visiting all the local dealers I can locate to try out models and find out what they can supply.
I first looked at getting midi controllers and hooking them up to a sound module, but I can only find 3 88-key controllers, and none of them seems to be relaible. So now I'm looking for a good keyboard that gives me good versatility and can be upgraded with extra amp, sound modules, pedals, midi controller etc...
For now, I'm primarily looking for a keyboard with which I can practice the core technique of keyboarding with, which I severely lack at the moment, but which I can use later for recording and live performance without being forced to buy anyithing extra. What I listed for buying extra later will only be indulgences that I will probably get regardless.
On the side I want to practice pure piano peices and playing, since I really like the sound and expressiveness of the instrument. Not a big fan of buying a dedicated electric piano, and I can't buy a proper acoustic piano until I live on my own.
So yeah. What do you guys think?
5. Pitchbend wheel.
1. Sequencing
2. Sampling
