- Joined
- Jul 14, 2015
- Messages
- 2
- Reaction score
- 0
Hello.
(and sorry for my english - I'm from Belgium)
I'd like your advice for the following situation...
I'd like to amplify correctly (with realistic sounds) :
- a Nord Stage 2
- and / or an Hammond XK3c (just with the internal Leslie Simulation or with Neo Ventilator 2)
- and / or a Yamaha S90
For home usage, rehearsal, small concerts in small rooms (50-100 persons).
For max +-1200 €, not too heavy and too bulky...
According to different readings (I'm not a pro) :
It needs a stereo system (for some piano sounds in the Nord Stage, for the Leslie effect...), and stereo combo keyboards amps are not strongly recommended...
I found the following equipments that could match my needs :
HK Audio Lucas Nano 600
Yamaha Stagepas 600i
And possibly Motion Sound KP-500SN , Traynor K4, Line6 L3m... ?
Or possibly some other solutions ??
According to your experience, your knowledge, what's your opinion on the above equipments ?
(You can perhaps to sort them,give your top 3, or to suggest other solution).
I thank you all.
André
- a Nord Stage 2
I thank you all.
André
