CASİO CTK 900 MİDİ CABLE CONNECTİN PROBLEM (HELP!!)
hello to everyone, sorry for my bad english,, my problem is when i connected my keyboard to pc, my keyboard does not send signal to pc but pc can sent signal to keyboard, for exsample, i can change piano sound mode from pc at casio data center,, or i can listen a piano song at Synthesia program from my keyboard, BUT my keyboard did not sent signal to pc..
i do not know OX program but i took this results..
green side is when i sent signal to keyboard(my keyboard making piano sound) red ones are when i press to keyboard buttons, also sometime red side became pruble
and this is my midi cable
tnx for help
Check the Casio's Menus.
MIDI may be turned off.
I seem to recall on some older Casios, MIDI was turned off by default.
still i cannot solve this problem, there is no midi on off setting on keyboard, i can play piano from my pc keybord but i cannot sent message to computer
In that link it mentions 16 channel MIDI receive. NOT MIDI Send.
I think you are out of luck.
it is imposible, even older and cheapest casio ctk models got midi control sent and take function,, this is casio ctk 900 high grade model of it,s area, casio ctk 496 which are cheap model, it is today still using as midi keyboard...
Hey did you find how to do it? I'm struggling because I don't know if it's possible so please If you have the answer share it
