Casio WK-200
Does anyone know how to adjust the volume independently when using dual play on the casio WK-200? example: When playing both strings & piano, I want the piano to be louder than the strings.
You have to edit a tone - then save it to your tone list. You may have a piano tone with the volume saved at full (127 - number 01), and the string tone saved at half (64 - number 02). You then need bring up the saved piano tone, then layer the saved string tone. Then you can save the entire dual-layered created tone to your Casio's memory list.
golek
