CP33 midi problems
I used to have my Yamaha cp33 connected to my pc through midi and now that i have disconnected the midi i cant get sound from my speakers. is there a master reset for the Yamaha cp33. How do i get out of midi mode and back to normal configuration?
thanks
what speakers? CP33 doesn't have speakers, and you can't play CP33 sounds on PC via midi cable.
CP33 has the "MASTER" button which toggles master keyboard/normal keyboard mode (master for midi and normal for... well... normal playing :D)
I don't have a CP33, but would check to see if there is a "local" on/off mode.
Possibly the local control has been set to "off".
