Looking for recommendations for home use, no gigs or bands.
I'm an acoustic piano player located in the US. I've never used an arranger, workstation or synth. I've used a small, simple MIDI connected to a DAW. There are no available physical stores to try things out. I have powered KRK speakers I can use.
Looking for thoughts/opinions/recommendations.
Thanks
- Important factors, high to low:
- Piano, organ sounds
- Keyboard feel, with less than 88 keys; keyboard will be on large desk
- Ability to use (not create) styles, backing tracks, rhythms, 1 finger chords, i.e. accompaniment options; ability to import and edit the same would be nice
- Split and layer
- Availability of world music instruments, sounds, rhythms would be nice; doesn't have to be built in if downloads are available
- Budget of less than $2000 preferred
- Don't care about hip hop, EDM features
- Ease of interface use and best learning curve.
Thanks
