Hi I have a psr S 500 I got my self a usb song stick when I put it in my keyboard the songs plays play ok the thing is I carnt work out how to play along with the songs .in the same ways as the songs on the keyboard? can any one help.. Thanks
Hi yes I am trying to mute one or more channels so I can play that part my selfI think you should be able to play the keyboard while a song is playing back by using the keyboard's voices (Right1, Right2, and Left, or whatever that model calls them-- on mine they're called Main, Dual, and Split). It should just be a matter of playing the keyboard.
So I'm wondering if there's more to your question-- for instance, are you trying to mute one or more channels of the songs so you can play those parts yourself, or something like that? Can you give a more precise explanation of what you're trying to accomplish?
