Fantom 08 Doesnt Seem to Receive or Respond to Program Changes in Midi
Toronto, Ontario
I’m trying to send Program Changes from an iPad to Roland Fantom 08 and there doesn’t seem to be any response from the keyboard. I am using the same hardware as with my previous keyboard which worked fine in this regards (iPad --> Camera adapter --> USB cable into the “computer” port of the keyboard).
The settings on the Keyboard’s midi section seem to be set right (Receive PC is on, for example).
I tried setting the “Scene Control Channel” to Midi Ch 1 and the factory setting of 16 and neither seems to do anything.
Any help is appreciated.
Netherlands
My settings:
Device ID 17
Scene Control Channel 15
USB-MIDI Thru OFF
Remote Keyboard Switch ON
All TRANSMIT and RECEIVE options ON
Toronto, Ontario
Thanks. I tried those, getting the same thing. I’m starting to doubt my hardware. ON another note, do you know where I can find the info for how to translate a Scene on the FA08 to the midi info (msb/lsb)?
Netherlands
I made a third page (this is getting out of hand) with all the LSB, MSB, Bankselect and Program Change data for the 512 different scenes in the Fantom 06/07/08. Hope that helps.
All databases are searchable, sortable, downloadable (CSV, XLS or ODS).
golek
