Gotek Floppy Disk Emulator Upgrade Technics KN6500
Hello just wondering if anyone here as successfully managed to upgrade their Technics KN6500 with a Gotek floppy disk emulator. I've just installed mine, however I have ran into a problem. I can see and select the disk images on the emulator, but when I try and load anything from the keyboard disc menu it asks me to format the disk which I did and then I get an error message. I have attached photos of the problem. Hopefully someone can help here. I've searched online for solutions and found nothing.
Thanks Biggles, This the was the first thing I checked when I joined the forum, but I didn't find the answer I was looking for and I've still not solved the problem so far.
If you search again but just for Emulators then although the results will be for other models a lightband the end of the tunnel may be seen.
There again it may be just some blighter with a torch.
